CREATING CASES AND CHILD CASES - don't see the Child case in dropdown
Following are the instructions from the exercise CREATING CASES AND CHILD CASES in CASE DESIGN section of course System Architect Essentials :
Configure the Onboarding case type to create a Benefits Enrollment child case
Configure an onboarding case to create a benefits enrollment case as a child case. This requires the user to complete the benefits enrollment case before they can complete the onboarding case.
- Under the Benefits enrollment stage, click + Add process.
- Under the Benefits enrollment step, click + Add step. A pop-up opens to select the type of step to add.
- Select More > Utilities > Create Case(s).
- Click Select. A second step is added to the process.
- In the highlighted field, enter Select Benefits.
- In the properties panel for the Select Benefits step, select Create a child case.
- From the Case type drop-down field, select Benefits Enrollment.
- Delete the first step in the process.
Click Save.
Click Save.
But after reaching to this point I don't see Benefits Enrollment in the dropdown (PFA). Please help to advance in the exercises because these exercises are not mutually exclusive.
Asher
***Updated by moderator: Lochan to move post from PSC to Pega Academy***
