Could not aquire fresh access token - OAuth 2.0 authentication issue
I'm facing an issue with the OAuth 2.0 authentication in Pega. Here is the error message I'm getting when running the Connector REST from a Data Page.
Here are some details I've caught in logs:
I'm not sure why this is pointing out the wrong JWT JSON token configuration since I'm not using it. Instead, the Client secret Client authentication is used.
Please help, maybe you encountered the same problem.
Cheers, Bartek.
