Converting JSON to Clipboard
Hello :)
I am having trouble parsing the JSON data that I have to Clipboard. The following JSON contains the following structure (response trimmed for brevity but it's still valid JSON):
"data":{
"products":{
"161630882":{
"addedBy":"SYSTEM",
"creationDate":"2019-03-28T10:33:34.787"
"orderProducts":{
"161630882":{
"bundleId":101930536,
"bundleOrder":5000
However, @(Pega-RULES:Page).pxConvertStringToPage(tools,myStepPage,.Response,"json") returns an error with "The reference 161630882 is not valid. Reason: invalid property name: '161630882'". adoptJSONObject function returns the same error.
So the question is: If Pega is unable to parse integers as properties, how can we be able to convert this JSON to clipboard? Note that we cannot modify the structure of the JSON as that same structure is being used in multiple areas of our systems.
Any help is appreciated! :)
When we create a Pega property, for the Identifier, it needs to be a name that starts with a letter, and use only letters, numbers, and hyphens, forming a java identifier.
https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm#rule-/rule-obj-/rule-obj-property/new.htm
For a value of "161630882" [ starts with a number], you will receive "invalid property name" error.
