convert clipboard page and/or xml to json
What is the best way to convert a clipboard page and/or xml to json in pega 7.1.5? I imagine there is a java method or pega function that is invoked for REST service functionality... my needs are not REST-specific, but I should be able to use the same assets.
Pegasystems Inc (Test Account 2)
The ClipboardPage java API has JSON and XML conversion methods - adoptJSONObject, adoptJSONArray, and adoptXMLForm for populating a clipboard page with JSON/XML data, getJSON and getXML for converting the contents of a clipboard page to an JSON/XML string value.
thanks. that did the trick; i created a simple function that serves my needs:
PublicAPI tools = (PegaAPI) ThreadContainer.get().getPublicAPI();
ClipboardPage stepPage = tools.getStepPage();
String retValue = stepPage.getJSON(false);
return retValue;
HCL
Hi BONDJ,
My requirement is convert clipboard Page to JSON format.
Can you help me on the same.
Thank You
Ramesh Thimmapur
Nielsen
Hi BONDJ,
The above method will also print pxobjclass. Anyway to suppress that?
Regards
Amit
This might help:
com.pega.dsm.dnode.util.ClipboardPageJsonConverter converter = new com.pega.dsm.dnode.util.ClipboardPageJsonConverter(false);
net.sf.json.JSONObject json_obj=net.sf.json.JSONObject.fromObject( converter.asJsonString( tools.getStepPage() ) );
net.sf.json.JSONObject stripped_json_obj=new net.sf.json.JSONObject();
Iterator<?> keys = json_obj.keys();
while( keys.hasNext() ) {
String key = (String)keys.next();
if ( (!( key.startsWith("px") )) && (!( key.startsWith("py") )) && (!( key.startsWith("pz") )) ) {
stripped_json_obj.put( key , json_obj.get(key) );
Or this:
// generate json from this template
converter.setPrettyPrint(true);
java.nio.ByteBuffer json = converter.asJson(sourcePage);
String jsonString = new String(json.array());
// remove pxObjClass
jsonString = jsonString.replaceAll("\"pxObjClass\"\\s*?:\\s*?\".*?\",?\\s+", "");
return jsonString;
The class/package names may need to altered - depending on your version of PRPC (The first example comes from PRPC72 for instance).
This might help:
Or this:
return jsonString;
The JSON handling/conversions in upcoming versions of PRPC will be improved to provide an easier way to perform JSON<->Property mappings; but unfortunately (as far as I know) - you are stuck with having to 'post-process' the JSON as shown above.
Virtusa Consulting Services
We are having issue with the above given snippets..
"net.sf.json cannot be resolved to a type"
what should be the approach?
What version of PRPC are you using ? It is possible that library I used in the snippet isn't shipped with that version.
If you check 'pr_engineclasses' table - look for anything that has the word 'json' in it as a starting point.
So: something like this:
select distinct(pzjar) from pr_engineclasses
where upper(pzpackage) like '%JSON%'
or upper(pzjar) like '%JSON%'
order by pzjar;
And then basically - see if the JARs are well-known third-party jars, and then check the javadocs for a function that could help.
(it's a bit hacky the above: but that's what I did to find the 'net.sf.json' in the first place!)
Cognizant
I have simmilar requirement to send JsonObject in Rest Header, I have used the below code to convert Clipboard object to JSON but it gives me a JSON object with pxObjClass. I tried the above approach mentioned but no luck. Please help me
