Connecting to MQ from tomcat
We are trying to connect to a MQ using Connect-MQ from our pega instance installed on tomcat. I could read from varioud posts that we need to import the below set of jars to the tomcat/lib directory. However I am not clear on the below points:
1. The concrete list of jars required.
2. What DSS setting we need to set. Can you please tell the exact value that needs to be set.
3. Is a restart required after importing the jars?
4. Should jars be imported by like we import packages or by placing them in the folder directly outside pega.
