HSBC
Last activity: 6 Oct 2016 13:11 EDT
Connect JMS in Tomcat 6.0.37 via Resource Reference
I am trying to Connect-JMS to a tibco queue using a P2P connection. I have created following entries in:
1) /prweb/WEB-INF/web.xml
<resource-ref id="ResourceRef_11">
<description>location of JMS Connection Queue</description>
<res-ref-name>jms/QueueConnectionFactory</res-ref-name>
<res-type>javax.jms.QueueConnectionFactory</res-type>
<res-auth>Container</res-auth>
<res-sharing-scope>Shareable</res-sharing-scope>
</resource-ref>
2) /tomcat/Context.xml --> XXXXXXX mentioned below is replaced with the actual URL which is working fine with the Direct JNDI lookup in the JNDI Server Rule
</resource-ref>
<Resource name="jms/QueueConnectionFactory"
auth="Container"
type="javax.jms.QueueConnectionFactory"
initialContextFactory="com.tibco.tibjms.naming.TibjmsInitialContextFactory"
url="tcp://XXXXXXXX"
username="admin"
password="admin"
3) /tomcat/conf/Server.xml
auth="Container"
type="com.tibco.tibjms.naming.TibjmsInitialContextFactory"
factory="com.tibco.tibjms.naming.TibjmsInitialContextFactory"
brokerurl="tcp://XXXXXX"
username="admin"
password="admin"
4) In addition to above I have created a Connect JMS rule in Pega in which I am trying to do a Resource Reference look up as java:comp/env/jms/QueueConnectionFactory. I also tried to perform a lookup via '/jms/QueueConnectionFactory', but that too didn't worked.
This connection always throws an execption when I try to do a test connectivity via the Connect-JMS Rule.
JNDI lookup of JMS connection factory 'QueueConnectionFactory' failed: javax.naming.NameNotFoundException: Name QueueConnectionFactory is not bound in this Context
Alternatively, If i try to do the same via Direct JNDI Lookup and specify the same TCP url, username and password in the JNDI Server Rule, I am able to connect Successfully.
