HSBC
Last activity: 5 Mar 2019 5:25 EST
Connect-Sql RULE : Class References in query are not getting evaluated to Schema.TableName
I have a db query, Delete from {class:A} f where f.PXINTERACTIONID in (select interactionid from {class:B} where passedlimit='false' and campaignrunid = '{ASIS : MTemp.CAMPAIGNRUNID}' ).
The problem is when I hard code the schema and table names then only above query runs, else we get an error "ORA-00942: table or view does not exist ". However I when I do Test Connectivity from Connect-Sql rule with class references, the schema and table name are picked up correctly.
Database Table mapping is also in place.
Anyone faced this issue before?? Please help
