Virtusa
Connect-SQL Schema
Hi Team,
We have created one data table in PEGA schema and using connect-SQL i tried to connect to the table to perform Create/Delete/Update operations. In the connect SQL i did not mention any schema before table name, i called this SQL on the page where the class of this page is mapped to the table using Data base table rule. I am able to connect this table in E1 dev environment. At run time schema name will be getting from the data base table urle.
But when it moves to E2-UAT environment, it is not working. But if i hard code the schema name before the table in the connect-SQL rule it is working properly.
Could you please suggest why it is behaving differently in higher environments.
Chiranjeevi M
