component not sited error while adding object in automation
Hi Team,
As per the video in HTML Table Designer and For loops, I have interrogated with HTML Table designer and select element for Anchor link.
Using Attribute value match rule on Process Case link to perform click.
My requirement is to click on each Process Case link.
For that I am using For loop to match workstatus value, if true then perform click.
But having component not sited error whenever trying to add perform click method. No valid log found.
Screenshot is attached. Please help.
Kousik
