Closed Database connections, Pega not responding
Greetings.. We are on Pega 7.3.1, Database PostGresSQL and application server as Tomcat on Amazon AWS, we are trying to shut down RDS by keeping EC2 instances active and when RDS is started and actively available, Pega application is not being recovered. A lot of similar errors as below are cropped into logs
2019-06-19 15:40:07,790 [egaRULES-MasterAgent] [ STANDARD] [ ] [ ] (luster.external.SystemNodesDAO) ERROR - Failed to update System-Status-Node instance: Database-General Problem encountered when getting connection for database pegarules 0 08003 This connection has been closed.
DatabaseException caused by prior exception: org.postgresql.util.PSQLException: This connection has been closed.
| SQL Code: 0 | SQL State: 08003
Any ideas/suggestions?
Bharat
