Accenture
Last activity: 13 May 2017 5:39 EDT
Close window block is not working in Open span
Hi Team,
Is there a possibility to increase the stability of the close window method?
I have used delay as well as the activate window method before close window method to increase its stability and also a check if the window is present is also there. Even then the window is still not closing. Any thoughts or suggestions in this regard?
