Change of Compatability setting in KAFKA Avro Schema
We are pushing data to KAFKA in Avro data format via data set. In Avro Schema rule, "perform schema evaluation when reading messages" checkbox is checked to enable backwards compatibility. However, we need to update to BOTH compatibility.
Is there way to change the combability settings in Pega Avro schema to BOTH or FORWARD.
And, does this setting apply when consume data if data set uses the same Avro schema rule?
