Certificates used by NPI connector (PEGA Exchange)
Hello All,
Is it possible to know what certificates does the NPI connector end point URL (https://npiregistry.cms.hhs.gov/api/demo) uses?
When I initially downloaded the NPI connector from PEGA Exchange and established the connection I encountered certificate chaining error for VeriSign as below:
internal cause is:
java.security.cert.CertPathValidatorException: The certificate issued by CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU="(c) 2006 VeriSign, Inc. - For authorized use only", OU=VeriSign Trust Network, O="VeriSign, Inc.", C=US is not trusted; internal cause is:
java.security.cert.CertPathValidatorException: Certificate chaining error
(NOTE: We fixed the above issue by adding the certificate to default truststore in websphere)
This morning when I was attempting to establish the connection I am getting certificate chaining error for Entrust as below:
internal cause is:
java.security.cert.CertPathValidatorException: The certificate issued by CN=Entrust Root Certification Authority, OU="(c) 2006 Entrust, Inc.", OU=www.entrust.net/CPS is incorporated by reference, O="Entrust, Inc.", C=US is not trusted; internal cause is:
Hello All,
internal cause is:
internal cause is:
Does the certificate change very often? If yes, is there any way to handle this situation?
Thank you in advance.
