Accenture
Last activity: 30 Dec 2021 1:49 EST
Case not updating when visibility condition is set on 'pyupdatecasedetails'
I've added 'pyupdatecasedetails' to pyDefault under 'Case wide actions' in order for my case to update via Pega API.
As per requirement, the local action should not be visible under the 'Actions' button when the case is opened on the UI. For that, I added visibility condition (When: Never) for this local action. Post setting of visibility condition, I again started to get the same error: "pyudatecasedetails not part of assignment actions".
Is there a way that I keep 'pyupdatecasedetails' on my 'Case wide actions' yet it is not visible under actions menu?
@CSiddharth You need to Customize the pyWorkActionsPopulatePerform Activity / pyWorkActionsPerform Navigation rule into your work class by adding the logic to remove / hide the specific local action from the pyLocalActionsList page list property
