Case API POST how to find username and password
Hi ,
i am trying to access (Generate create case microservice code) my case post api from postman what should be username and password, where to get these details from .?
Venki
Hi ,
Venki
if you are talking about Pega API, check api service package defined in your pega application. If it is set as basic, you can pass your pega server login credential.
Hi @Venkaiahm ,
Create a operator and use that operator only for API related work.
To access the case data you need a operator with the listed roles below
