Cannot view the Test Cases when switching between PegaUnit testing and Automated Unit Testing
Under PegaUnit Testing I have created many test cases as you can see below:
Also, I have followed this link to create the Ruleset under which I am saving my Test Cases under https://community.pega.com/sites/default/files/help_v722/designer%20studio/testing%20rules/setup%20cleanup/ds-setting-up-environment-for-testing-tsk.htm
When I switch to the old version to the Automated Unit Testing (and logging off after the switch) in order to use the scheduler, I cannot see anything under the 'Unit Test Cases' as you can below:
PS I have added the PegaRULES:AutoTest Role to my access group and it has a privilege 4, as you can see below.
Note that I am using Pega Version 7.2.2
Are there any missing configurations that needs to be set in order to view the Test Cases when switching between PegaUnit testing and Automated Unit Testing ??
Thank you,
Mariane
