Busy Indicator mask only half screen
I have a section with huge content. At the bottom of the screen there is a submit button. When the button is clicked , the portion of the screen that is visible is not masked whereas if I scroll up I see that the upper portion of the screen is masked with busy indicator. How can I mask the lower portion of the screen as well?
Hi Singhal,
What version of PRPC are you using?
Busy indicator is usually displayed at the center of the screen.
Do you have any customized code for it?
Susan
