Macquarie Global services pvt ltd
Last activity: 15 Feb 2019 5:49 EST
Bulk Attachment Print
Hi All
I have to print all the attachment attached in case in one go. Please let me know if there is any OOTB to achieve this requirement.
For ex- Case-123 has five pdf attachment . The requirement is to give a button on top of attachment section and once user click on the button .All five attachment should get printed.
Thanks in Advance !!
Regards
Gaurav
Swedbank AB
SE
Hello Gaurav,
You could try to merge the attachments into one file and printing it on click of the button.
Sincerely,
Pawan
Thanks Pawan for response.
Now this requirement is no longer needed. But i tried to merge the document in on PDF . I could merge all the content in one page but i was not able to download.
Gaurav Singh
Hello Gaurav,
Agreeing with Pawan.
I'm thinking for all the attachments to print together, all files need to be downloaded together on a single click? Unsure about this but if its true, then this in itself is a challenge. HTTP does not support more than one file download at once.
Thank you,
Shreshta
Barclays UK PLC
Hi Gaurav,
You could have Zipped all the files at once on a single click and downloaded it.
Lakshmisuneetha katnam
LTI
customer is expecting to print all the attachment which are attached to different cases to be selected at once based on the some search creteria and given for print(Bulk print) rather than going to each case and open and print.
Please suggest.
Sajjad
Centene Corporation
Hello
Anyone able to achieve this. I have cases with .docx attachments on them and the user needs the ability to print all of them (or few of them) at once with out having to open each one of them and print.
Any help is greatly appreciated.
Cherry Faizi
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
Aaseya IT Services Pvt LTD
Hi ,
You can see the post shared by me in the same chain. I have created a sample POC my application with the same. Working fine for me.
I was able to perform bulk print for multiple cases at single button click. I have attached the POC document for the same. Please refer to the document.
