Bug fix for Existing requestor retrieved?
Do we know when we can expect the fix for Bug-311189, as mentioned in SA-39642?
Hi Susan,
Do we have a hotfix for this issue in 7.2.2?
Hello Anoojit,
There is no available hotfix for this in Pega 7.2.2. This has been fixed in Pega 7.3.1 as an enhancement.
Thank you,
Shreshta
Hi Shreshta,
How do we resolve this issue?
Sreekanth
Hi Shreshta,
same question here. Will the fix be ported to 7.2.2? I assume more customers are working on 7.2.2.
Maurice Boer
Please note that a Hfix is not available for this Bug since Hfixes are for serious product defects whereas this Bug fix is cosmetic in nature. "Last input" field is typically populated with useful information that helps end user to analyze where the issues lie. This field does not hold value in the context of PEGA0069 alerts and hence contained "existing requestor retrieved" message. Therefore, to resolve this bug, we will not output any data for the "lastInput" field for any PEGA00069 alerts.
HI,
I just checked it for you.
Bug-31189 issue was found in Release Pega 7.2.2 and it is fixed in Pega 7.3.1.
If your application is on Pega 7.3.1, it should have the fix.
Susan
