USAA
MX
Last activity: 15 Jan 2025 5:27 EST
Broken items in a queue processor due to HTMLToPDF (PD4ML) issues
There are some broken items in our QP due to some issues with the PD4ML library used in the process of converting the HTML string to a PDF, the error says the following:
pyException = “Caught exception while resolving static file named initial.”
Already check the PEGA blogs and the documentation from the official website from the PD4ML library.
There are only a handful of cases as broken items, if I requeue them they stay broken, the incidents occurred in September, October, and November 2024, it hasn’t happened ever since then.
Not sure if it is a compatibility issue because application is pega 8.8.4 with a version of the PD4ML library V4.0.13fx7 or a special character that is noncompatible that was added only in those cases and it doesn’t allow them to be processed.
Anybody knows what could be the issue?
