Areteans Technology Solutions
Last activity: 15 Feb 2019 14:27 EST
Are the parameter names and values in prconfig.xml case sensitive?
If the parameter values in prconfig.xml are written in lower case, will those parameters be effective?
For example, if the below parameters in prconfig.xml,
<env name="initServices/initEmail" value="false"/>
<env name="initServices/initFile" value="false"/>
<env name="initServices/initJMS" value="false"/>
<env name="initServices/initMQ" value="false"/>
are written as,
<env name="initservices/initemail" value="false"/>
<env name="initservices/initfile" value="false"/>
<env name="initservices/initjms" value="false"/>
<env name="initservices/initmq" value="false"/>
will there be any issue?
If the value 'false' or 'true' are written as 'FALSE' or 'False' or 'TRUE' or 'True' will that make any difference?
Hi Debraj,
To answer your query it depends on the Database and O/S that you are using. So, i would recommend to use the mixed case which Pega has documented.
Mahesh M
