Anthem
Last activity: 6 Dec 2018 6:19 EST
AES Database performance review
Hi Andy,
Could you please review the attached AES database related AWR and PegaRules and PegaAlert logs and provide subsequent recommendations.
AES 731 and Monitored nodes version 731.
Following errors and SQL queries are observed high in number :
From PegaRules log :
1) 2018-12-04 00:01:02,646 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ AES:07.30] ( internal.mgmt.Executable) ERROR Rule-Connect-SOAP.PegaAES-Data-RSSnapshot.GetRuleSetSnapshot - Exception
com.pega.pegarules.pub.services.ResourceUnavailableException: SOAP service failed
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2)2018-12-04 00:30:17,662 [ttp-nio-8080-exec-62] [ STANDARD] [ ] [ AES:07.30] ( internal.util.PRParseUtils) ERROR va10n40604| Proprietary information hidden|SOAP|PegaAES|Events|logAlert|A2R1EOW0OWA9AFZ6S082F2EH1GSH5KFVM - XML parsing failed
com.pega.pegarules.pub.PRException: Failed to parse XML. Error: Content is not allowed in prolog.
PegaAlert Logs :
1) Database operation took more than the threshold of 500 ms: 58,857 ms SQL: DELETE FROM DEVKM_PEGADATA.pegaam_alert "PC0" WHERE ( ( "PC0"."CLUSTERNAME" = ? ) AND ( "PC0"."GENERATEDDATETIME" ? ) ) AND "PC0"."PXOBJCLASS" = ?
Last Input : PegaAES-.CallcleanupAESAgent
Hi Andy,
PegaAlert Logs :
2)Database operation took more than the threshold of 500 ms: 8,406 ms SQL: SELECT COUNT(ASTERISK) AS "pySummaryCount(1)" , MIN("PC0"."GENERATEDDATETIME") AS "pySummaryDateTime(1)" , MAX("PC0"."GENERATEDDATETIME") AS "pySummaryDateTime(2)" FROM DEVKM_PEGADATA.pegaam_exception "PC0" WHERE ( "PC0"."PROBLEMCORRELATION" = ? ) AND "PC0"."PXOBJCLASS" = ?
Hi Moderators,
Please route this post details to Andy <Removed>.
Thank you.
***Moderator Edit-Vidyaranjan: Removed personal information***
