Advanced Encryption Standard 192
On mesh all the docs gave AES 128 implementation, Pega Cloud uses AES 256.
Anyone has the detailed implementation guide on AES 192? What param to set? Or is the JRE defined?
We are using Pega 7.1.8, tomcat, oracle.
SR-A77553 is created.
I got a jar with 192 String Key, imported to my PE 7.1.9, it works.
But on cloud, the same jar doesn't work.
Then We did runPega, compileAndLoad scripts on the cloud, it didn't work.
Are these 2 scripts mandatory on each environment? Can I use the same jar to be imported using regular import? In stead of run compileAndLoad?
Dongsheng
Message was edited by: Marissa Rogers - Updated Categories
