Caprus IT Inc
Add(Object item) is not present in Explore Component Properties
Hi Guys,
I am trying to add items to combo box control dynamically using automation. To do it I explored the steps give in "Populating a ListBox/Combobox" from the page show in this link http://help.openspan.com/52/Components/ListBox_ComboBox_with_User-drawn_Items.htm .
In the Pega Robotics studio I am not able to see Add(Object) under Items. Please let me know if I am doing anything wrong.
OS : Windows 8.1/64 bit.
Pls refer the studio screenshot.
K.Naveen Kumar
It looks like you skipped steps 6-8 in the link you posted. You will need to click on the Items property and then click ConfigureType. Here is a screenshot.
Caprus IT Inc
Yes, I was missing those steps. Thanks for the information
Standard & Poors
Hi Guys,
i did steps 6 to 8 but still i am not seeing Add and Remove methods in Object inspector, Please let me know if I am doing anything wrong.
Please refer attached screen shot.
Anji.
Russel Kuate
You should have your automation open when adding this method. Once you see it in Object Explorer, you can drag it onto your automation surface.
Standard & Poors
Thanks for your response.
Form Configure Type window i have selected the required methods(Add,Remove) and click on OK, Normally those methods will available in Object Inspector window,Show Methods only section.
But these methods(Add,Remove) methods are not available/not showing to drag into automation.
Please check attached screen shot.
Anji.
As an alternative route, you can drag the "Items" into your automation and then extract a proxy out of the data output. This should create a ObjectCollection proxy control that you can access the methods and properties through. This issue seems to arise for builds after 1053.
Standard & Poors
Can you please elaborate your explanation or if possible can you please provide the screen shot with steps.
Anji.
I have posted screenshots for clarification below.
Updated: 26 Sep 2017 9:21 EDT
CIBC
thank you Vegam,
Can you elaborate the steps to extract a proxy? and how to use the ObjectCollection proxy control?
Thank you
Liza
1. Go to the control's properties and drag the 'Items' into an automation.
2. Right click the data output for the Items and choose Extract Proxy.
3. A new control is created and you are able to access the Add method.
CIBC
Hi Vegam,
This is awesome, thank you very much for your help, really appreciate it.
Liza
CIBC
Hi Vegam,
I don't think I'm using the proxy properly, since when I ran the automation, the following exception appears. Would you mind to help showing me how use the proxy Add method properly?
1) Exception Information
Exception Type: OpenSpan.Automation.AutomationException
EventLink: OpenSpan.Automation.EventLink
ThrowingLink: OpenSpan.Automation.EventLink
MachineName:
CreatedDateTime: 10/2/2017 2:49:40 PM
AppDomainName: "OpenSpan.Runtime.exe"
ThreadIdentityName: ""
WindowsIdentityName:
AdditionalInformation: NameValueCollection with 0 items
Message: "Error executing link in Automation: Main_E_IntMgr_InteractionStarted - From: _Main_GC.IntMgr.InteractionStarted To: Main_E_IntMgr_InteractionStarted.objectCollectionProxy1.Add()
GetWorkingInstance() could not get instance from TypeProxy. InstanceName: objectCollectionProxy1"
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: NULL
HelpLink: NULL
Source: NULL
HResult: -2146232832
Hi Vegam,
MachineName:
TargetSite: NULL
HelpLink: NULL
Source: NULL
2) Exception Information
Exception Type: System.NullReferenceException
Message: "GetWorkingInstance() could not get instance from TypeProxy. InstanceName: objectCollectionProxy1"
TargetSite: System.Object GetWorkingInstance(OpenSpan.Automation.ConnectableHost, OpenSpan.Automation.ExecutionEventArgs)
HelpLink: NULL
Source: "OpenSpan.Automation"
HResult: -2147467261
StackTrace Information
at OpenSpan.Automation.ConnectableHost.GetWorkingInstance(ConnectableHost connectableHost, ExecutionEventArgs executionArgs)
at OpenSpan.Automation.ConnectableWorker.DoWork(Object sender, ExecutionEventArgs executionArgs)
thank you
Liza
Infosys
I'm seeing the same issue as well.
I ran the steps 6 - 8, and on clicking OK, the Add and Remove methods don't appear.
I'm running Windows 10 64-bit, PEGA_RAS_8_0_1053, and Pega Robotics Studio 14.0.25420.1 D14REL.
CIBC
I'm having the same issue. anyone resolved this?
Thank you.
This is a known issue that is currently being worked on. Please refer to my suggestion above as a workaround.
Accenture Brazil
BR
Did someone solve this?
Nationwide
I am still having the same issue and the workaround above doesn't work. Has this issue been addressed?
BOA
i am also having the same issue. i just assigned the datasource as result instead of for loop and adding items to it. please try, if applies.
This issue is resolved in builds 8.0.1061 or later.
