Infosys
Last activity: 6 Jul 2017 1:43 EDT
Activity
I had used "Property-Set-Messages" method in activity to set a message on a particular property , but when I correct all the elements in the property the error message is displaying on the Page.
Coforge DPA
Hi ,
Try this option, uncheck "Always Show" check box in Harness rule.
Manikumar
BlueRose Technologies
SE
Hi Mahesh,
Can you please clarify your statement "when i correct all the elements in the property". Is that mean you gave right values to the property.
If yes, please trace of your activity when you are getting the error message on the screen.
Prudhvi
Credera
In Harness rule of this section, uncheck show field error message on page checkbox to hide at top page level and display only at field level
Which version of PRPC are you on. Please check "Display Options" tab in Harness rule, select only "Field level error" enabled. "Always show" should also be disabled.
could you please try the options as in the attached. You can play with these options.
Coforge DPA
Hi ,
Manikumar
Arshdeep Kaur Randhawa
Infosys
Thank You Guys For your reply...
I Got the answer..
Happy to hear that you found the Answer! Please share it here for the benifit of this community.
Thankyou,
Infosys
Sorry for late reply but now i am not remembering , will let know if i got time to look into it.
