Water NSW
Last activity: 5 Oct 2021 9:35 EDT
Accessing Pega Case from External System
One of our clients is looking for below requirement.
System A (External System) will have a button / link to open the case in Pega. When the user clicks the button, user should be redirected to Pega :
Assumption : User accessing System A will also have access to Pega.
1. User should be redirected to Pega in a new browser session. User should be authenticated with SSO and case should be available in the the perform mode for the user to process it.
2. If the user was already logged in to Pega , case should be opened in a new tab in the existing session without disturbing or loosing changes in the existing session.
Could you please share your thoughts on how to achieve this.
@SudhaSundeepD ,
Did you explored the Snapstart URL for your requirement.
If not, please explore the Snapstart URL once: https://community.pega.com/sites/default/files/help_v73/procomhelpmain.htm#mobile/concepts/mob-use-snapstart-module-outside-sdk-con.htm%3FTocPath%3DMobility%7CConfiguring%2520a%2520custom%2520mobile%2520app%7CAdvanced%2520features%7C_____3
