Accessibility issue when a Screen Reader/assistant calls out a button control which has Keyboard shortcut key
For a button control we have configured a keyboard shortcut as part of accessibility, shortcut is working as expected but when user uses voice assistant then the "Add" button is announced as
"A dd", which is incorrect and confuses VoiceOver users. here we need both shortcut and also voice assistant should clearly call it out as "Add". Can you please suggest the solutions?
Eg: &Add (this is how Pega recommended (Localization consideration) to use) in UI it displays as Add.
Current Code:
<button data-test-id="201707260528580280148864" data-ctl="" name="SearchHeader_pyWorkPage_44" accesskey="A" class="pzhc pzbutton" type="button" ><u data-keyboard="." data-click=".">A</u>dd</button>
Expected Code:
<button data-test-id="201707260528580280148864" data-ctl="" name="SearchHeader_pyWorkPage_44" accesskey="A" class="pzhc pzbutton" type="button">Add</button>
Note: with tittle attribute that is by providing "helper text" is not accepted
