Issue
A compatibility issue might affect certain near-zero downtime update scenarios involving environments running Pega Platform '24.x or earlier releases when updating to Pega Platform ’25.1.x or Pega Platform ’26.1 releases.
During the transition period, users might experience intermittent issues with case processing until all nodes have been restarted.
Symptoms and Impact
During the update process, the keystore data format changes from JKS to BCFKS as part of the data update phase. In environments that are undergoing a rolling restart, Constellation application nodes may start looking for a keystore format that earlier releases of the Pega Platform engines do not support.
During this transition period, users might experience intermittent issues with case processing until all nodes have been restarted. The issue is limited to the period between completion of the data update and the restart of all cluster nodes. Once nodes are restarted on the target release, normal processing resumes.
Initial Solution
Until hotfixes become available on the source Pega Platform release, perform the near-zero downtime update during a maintenance window where the system is not used until the rolling restart is completed on all nodes. This approach avoids the transitional compatibility gap and ensures uninterrupted operation.
Available Hotfixes
Please make sure that the hotfix applicable to your platform version is installed on the source system before initiating the update process to Pega Platform ’25.1.x or ’26.1 versions.
A restart of all nodes in the environment is necessary for the hotfix to take effect.
If you are not on a version where a hotfix is provided, you will need to update to the latest patch release that provides the near-zero downtime hotfix.
Advisory |
Description |
Patch Remediation |
Hotfix Remediation |
Near-zero Downtime Updates for Pega Platform 25.1.x or 26.1 |
24.1.5 Patch Release (Target Aug 21st 2026)
24.2.5 - HFIX-D2452 24.1.4 - HFIX-D2389 23.1.5 - HFIX-D2451 8.8.5 - HFIX-D2390 |
Obtaining your Hotfixes
Hotfixes are being created only for the patch releases listed above, under Hotfix Remediation. A restart is needed after hotfix installation.
We will not provide hotfixes on prior versions of Pega Platform.
- Pega Cloud® and United States Pega Cloud for Government (PCFG) clients, using the versions listed above, will have hotfixes applied proactively, with Cloud Maintenance (CM) cases detailing the schedule.
- On-premises or client-managed cloud clients should check the table above for applicable hotfixes and download them directly from My Security Hotfixes on My Pega.
If you have questions or concerns, please raise a Support Ticket in My Support Portal.
