Where can i find information on HFIX-C4306
Hi @wills4,
There is no specific documentation available about HFIX-C4306 but you can obtain detailed information about specific hotfixes by opening a Support Request (SR) with Pega.
Access My Support Portal: Go to the My Support Portal on PDN
Create a New Request: Click on the orange button that says 'Create'.
Select Request Type: In the 'Request Type' dropdown list, select 'Existing Hotfix Request'.
Enter Hotfix ID: Enter the HFIX-C4306 in the 'Requested Hotfix ID' field.
Verify Product and Version: Ensure that the Product and Version you select match the Product and Version the hotfix was built for. If there is a mismatch, the system will return an error and you won't be able to submit the request until this is resolved.
Fill in the Details: Complete the rest of the fields with the necessary information.
Submit the Request: Click 'Submit Request' to create your Support Request (SR) with Pega Global Client Support.
This way, the Pega support team can provide you with the necessary details and assist you further.
