How to change Constellation Form Step Vertical Navigation Labels from tight to Left
How to change Constellation Form Step Vertical Navigation Labels from tight to Left. Attached my view i want the labels of Form Steps to be displayed in left
@abdulr697 i think you can’t switch a Constellation Form Step “label position” to the left by configuration today. In Constellation, the form-progress component controls this and its layout is fixed by the design system. If you need labels always visible, use vertical navigation; horizontal shows only the current step label and others in tooltips. If your vertical nav is showing “tight” icon-only, it’s usually responsive behavior — give the stepper more width (wider page layout or fewer columns) so labels render. In App Studio, open your case > Workflow > Multi-step form and keep Navigation set to Vertical for label visibility. Avoid trying to override with CSS or sections because it breaks upgradeability. If left-aligned labels are a must, raise an enhancement request with Pega or build a custom Constellation SDK component as a last resort. References: Pega Support confirms vertical shows labels while horizontal doesn’t, and the design page documents the current form-progress behavior
Support Doc
