Social Security Administration
Last activity: 1 Aug 2025 8:22 EDT
PEGA0020 Alert, Total time for interaction has exceeded the threshold of 1,000 ms
How is a connector's run time calculated. Is this the just the time that PEGA is waiting for a response from the external service? Does it include the time it takes for the connector to run the request and response data transforms?
Pega Academy states
A connector defines an outbound request for information based on metadata that is published for the data source. Connectors establish a connection to an external system by using an agreed-upon framework to pass data, such as Simple Object Access Protocol (SOAP) or Representational State Transfer (REST). Connectors pass application data to an external data source through required or optional parameters and parse the response to map source data to the data structure used in the application.
When PEGA reports a 0020 alert, Does it include the request and response processing time?
