Tooltip in Chart
When creating a Chart, my Data Source is .Value taking the .UnitValue property to perform the sum. Would it be possible for the .Category property to be displayed in the tooltip, maintaining the sum?
Tks.
Tks.
Yes, you can show the .Category value in the chart tooltip while still using .UnitValue for the sum. To do this, make sure that .Category is used as the grouping or X-axis in the chart, and .UnitValue is used to calculate the sum on the Y-axis. When this is set correctly, the tooltip will automatically show the .Category along with the total .UnitValue. If it doesn't show as expected, check if there is an option to customize the tooltip format in your chart settings. In Pega charts, this setup will usually show the group (Category) and its corresponding total value automatically in the tooltip
Support Doc
