How to Get all Application List
Hi Is there any way to get all the application names
and Application related rules , AccesGroups and Operator ID's which are existing in Dev Portal
  You can create a report under the following classes
Rule-Application to get the application names
Data-Admin-Operator-ID to get the list of operators
Data-Admin-Operator-AccessGroup to get the list of Acces groups
  Hi @SwethaV83,
To all application list we have ootb report definition
pxFetchListOfApplications in Rule-Application class
We have ootb data page D_OperatorAccessGroups to get all access group
Run a Report Definition on Data-Admin-Operator-ID to list operators assigned to applications.
If you want to get all the above information in a single Report Definition,
Create a new Report Definition on Data-Admin-Operator-ID
Join it with Data-Admin-Operator-AccessGroup and Rule-Application
Display Application Name, Access Group, and Operator ID.
Regards
Mohd Qizer Uddin
  @SwethaV83 To get a list of all application names, related rules, Access Groups, and Operator IDs in the Pega Dev Portal, you can use several methods. First, you can query the Data-Admin-Application class for application names, and the Rule- classes (like Rule-Obj-Class) for related rules. For Access Groups, query the AccessGroup table, and for Operator IDs, query the Operator class. You can use Pega's REST or SOAP APIs to pull this data programmatically, or you can create custom reports in the Report Definition tool by selecting the appropriate classes. If you have database access, direct SQL queries can also retrieve this information from the respective tables. Additionally, the App Studio tools in Pega provide visual ways to view application and user-related data.
