Node initialize issue after upgrade to 24.1.2
The system is upgraded from 8.8.1 to 24.1.2 .one of the webnode is failed to initialize as throwing the below error in logs. while no errors in other nodes and the same cluster configuration works fine in 8.8.1 (in terms of IP address and Ports).
the cluster is having the 4 nodes
- stream :- 1
- Backgroundprocess/search/BIX :- 1
- web user --2
I tried to set <env name="services/stream/provider" value="Internal"/> in prconfig.xml of all nodes and cleaned up the stream related tables and kafka-data folder in stream node as well but still issue is persist. Are we missing something here on this node .?Please suggest.
- stream :- 1
- web user --2
2025-03-20 16:45:17,589 [ALIZE_STREAM_SERVICE] [ STANDARD] [ ] [ ] (.stream.StreamServiceValidator) ERROR - Failed to initialize StreamAPI: attempt 1 from 6. Next retry in 20 seconds java.util.concurrent.TimeoutException: null at java.util.concurrent.CompletableFuture.timedGet(CompletableFuture.java:1771) ~[?:1.8.0_202] at java.util.concurrent.CompletableFuture.get(CompletableFuture.java:1915) ~[?:1.8.0_202] at com.pega.platform.stream.StreamServiceValidator.ping(StreamServiceValidator.java:91) ~[stream.jar:?] at com.pega.platform.stream.StreamServiceValidator.validate(StreamServiceValidator.java:69) ~[stream.jar:?] at com.pega.platform.stream.StreamService.getStreamAPI(StreamService.java:74) ~[stream.jar:?] at com.pega.platform.modules.internal.guice.StreamServiceModule.createStreamAPI(StreamServiceModule.java:58) ~[modules-bridge.jar:?] at com.google.inject.internal.ProviderInternalFactory.provision(ProviderInternalFactory.java:81) ~[guice-4.0.jar:?] at com.google.inject.internal.InternalFactoryToInitializableAdapter.provision(InternalFactoryToInitializableAdapter.java:53) ~[guice-4.0.jar:?] at com.google.inject.internal.ProviderInternalFactory.circularGet(ProviderInternalFactory.java:61) ~[guice-4.0.jar:?] at com.google.inject.internal.InternalFactoryToInitializableAdapter.get(InternalFactoryToInitializableAdapter.java:45) ~[guice-4.0.jar:?] at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46) ~[guice-4.0.jar:?] at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1103) ~[guice-4.0.jar:?] at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40) ~[guice-4.0.jar:?] at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:145) ~[guice-4.0.jar:?] at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:41) ~[guice-4.0.jar:?] at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1016) ~[guice-4.0.jar:?] at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092) ~[guice-4.0.jar:?] at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1012) ~[guice-4.0.jar:?] at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1051) ~[guice-4.0.jar:?] at com.pega.platform.modules.internal.ModulesBridgeImpl.getStreamAPI(ModulesBridgeImpl.java:726) ~[modules-bridge.jar:?] at com.pega.dsm.dnode.api.server.StreamServerService.getStreamAPI(StreamServerService.java:232) ~[d-node.jar:?] at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.validateStreamAPI(StreamServiceInitializationTask.java:95) ~[d-node.jar:?] at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.access$100(StreamServiceInitializationTask.java:32) ~[d-node.jar:?] at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask$1.run(StreamServiceInitializationTask.java:82) ~[d-node.jar:?] at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask$1.run(StreamServiceInitializationTask.java:77) ~[d-node.jar:?] at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:77) ~[d-node.jar:?] at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper$2.run(ServiceHelper.java:295) ~[d-node.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1379) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1122) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:929) ~[prprivate-session.jar:?] at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:288) ~[d-node.jar:?] at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:150) ~[d-node.jar:?] at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.initStreamServerServiceAndValidate(StreamServiceInitializationTask.java:77) ~[d-node.jar:?] at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.runTask(StreamServiceInitializationTask.java:51) ~[d-node.jar:?] at com.pega.pegarules.session.internal.async.startup.StartupTask$1.run(StartupTask.java:55) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1379) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1122) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:929) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:895) ~[
***Edited by Moderator Marije to add Support Case Details ; INC-C13225**
