Pega Upgrade 24.1.2
What exactly difference between Upgrade.bat and Update.bat .Which file needs to be used for upgrade from 8.8.1 to 24.1.2
When we look at webpage in PegaPlatform media D:\Pega\118061_Pega_24.1.2\StartHere.html then it says as mentioned below.
The Installation and Upgrade Assistant tool requires a Java runtime environment. The command line scripts equivalents are in the /scripts directory of the Pega Platform media named: install.bat, install.sh, upgrade.bat, and upgrade.sh.
Few articles says run Update.bat.
- If you have not done so already, edit the setupDatabase.properties file.
- Open the setupDatabase.properties file in the scripts directory of your distribution image: Directories/distributionDirectory/scripts/setupDatabase.properties.
- Specify the appropriate options for your update. For each option, add the appropriate value after the equal sign.
- Configure the connection properties. Use the existing schema names for the rules schema and data schema names.
- Optional: If you have a separate customer data schema, set the target schema name:
pega.target.customerdata.schema=existing-customer-data-schema
pega.target.customerdata.schema=existing-customer-data-schema - Optional: If you are repeating a failed update, configure the resume property:
- To resume the update from the last successful step, set
automatic.resume=true. - To restart the update from the beginning, set
automatic.resume=false.
- Save and close the file.
- Open a command prompt and navigate to the scripts directory.
- Run either update.bat or update.sh
@BRAHMESH@ You can use upgrade.bat for your upgrades.
I am not 100% sure what the update batch file is used for, there isn't much in that file:
set SCRIPT_NAME=update.bat
call upgrade.bat %*
set SCRIPT_NAME=
set OPERATION_TYPE=
