JP
Last activity: 7 Mar 2025 5:57 EST
OAuth2 Client registration is not found for C11N Application
When you migrate a new C11N app from one environment to another, you might face login issue which generate exceptions like below..
(root cause)
Type com.pega.pegarules.pub.PRRuntimeException
Message OAuth2 Client registration is not found for C11N Application : aim. C11N Application must be registered as OAuth2 Client
Stack at com.pega.pegarules.session.internal.mgmt.authentication.AATTokenUtil.generateAndSetCookiesForConstellationAppln(AATTokenUtil.java:104)
at com.pega.pegarules.session.internal.mgmt.authentication.SchemePRAuth.performPostAuthentication(SchemePRAuth.java:814)
at com.pega.pegarules.session.internal.mgmt.authentication.SchemePRSPA.performPostAuthentication(SchemePRSPA.java:137)
at com.pega.pegarules.session.internal.mgmt.authentication.Authentication.executePostAuthenticationPolicies(Authentication.java:2952)
at com.pega.pegarules.session.internal.mgmt.authentication.Authentication.performPostAuthentication(Authentication.java:2940)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.handleAuthentication(HttpAPI.java:3021)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.activityExecutionProlog(EngineAPI.java:644)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:466)
at jdk.internal.reflect.GeneratedMethodAccessor174.invoke(Unknown:Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
"OAuth2 Client registration" is required for C11N application, and usually it will be generated automatically when you create a new C11N application.. however, "OAuth2 Client registration" may not be generated automatically when you import a RAP package for C11N application... you can not login to the new C11N application if this unfortunate situation happens... to solve the issue...
- login to the system with an operator id that has "PRPC:Administrators" as default access group.
- In devstudio, open the C11N application rule definition which "OAuth2 Client registration" is missing.
- In devstudio, open Rule-Application.pzRegisterConstellationAppAsOAuth2Client activity
- Run pzRegisterConstellationAppAsOAuth2Client from Actions menu
- Set the activity Run context.. Thread: {thread_of_C11N_app_rule}, Page: "Copy existing page", Page to copy: "RH_1(Rule-Application)"
- click Run..
- go to "OAuth 2.0 Client Registration" instance landing page (DevStudio > Rocords > Security), confirm PegaApp_{C11NApp} is generated.
