Why D_MKTOfferStatistics .Statistics page is setting to default values
Hi
I am exploring our pega academy on 24.1 of CDH, wondering why Action Impression rate, Volume, Conversion rates are marking as zero even though system had the data for the same. Please find the attached screen shots to understand what am I referring here,
When I debug, what I understood is that D_MKTOfferStatistics data page source data transform "RetrieveOfferStatistics", alternative path being executed. So wondering if any solved this issue. Inside the code what I see DetermineJourneyDates data transform required Param.LookbackInterval which is getting assigned as null which results D_MKTFilter failure.
Please help me with understanding on why this is not working in BOE and how to fix this.
Raja
