HomeServe
Last activity: 21 Feb 2025 6:13 EST
Calling datapage inside of Authentication services operator provisioning data transform causes it to error.
Hi, I am trying to call a datapage inside of an authentication services operator provisioning data transform
However it seems to consistently fail when logging in with a new user.
My datapage is fetching a model operator string from a class within the unauthenticated ruleset. The DT works if I statically set which model operator to use, but if I attempt to dynamically find it with the datapage then it will fail.
I have made sure that the requestor access group is able to see the ruleset. I have also ensured that AROs are set to allow unauthenticated users to use those classes.
I am unsure as to why it is erroring. The version I am using is PEGA 8.7
