crochetech
Last activity: 13 Dec 2024 9:48 EST
Styles Not Applying in Popup Window with Harness Action
I have a requirement where clicking on any link should open a Harness a new window.
However, the styles are not being applied to the launched Harness when I include the stylesheet in the Scripts & Styles tab of the harness.
When I launch a section in a modal using a local action, the UI renders correctly. But when I launch the same section in a popup window using a harness action, the UI does not render as expected.
From my understanding:
- The
Pzskinv2
CSS file is associated with the application skin, portal skin, or any custom skin applied to the portal. - The
Pzharnessv2
CSS file is associated with the harness and includes additional harness-specific stylesheets.
How can I override Pzharnessv2
to ensure it uses Pzskinv2
styles instead?
I suspect this could be a bug in Pega.
