How to close a Harness Popup window on click of Submit button
As part of our case, we have a Link in a section that opens a new Harness in new Pop-up window.
As a requirement we need to close the Harness pop-up window on click of Submit button.
We've already tried below option but it didn't work :
- Name the Harness Window field like "QSDocument" in the Action set of the Link
- Use a specific javascript to close explicitly the window with below code
var openedWindow;
function openWindow() {
openedWindow = window.open('QSDocument');
function closeOpenedWindow() {
openedWindow.close();
- Use Run script to call closeOpenedWindow as an Action in the Submit button to close the window
It unfortunately didn't work.
Do you know any other way of achieving this requirement ?
Kind Regards,
Djibril
var openedWindow;
Kind Regards,
Djibril
Hi Shashidhar,
Eventually i found a solution to get requestorId.
Basically instead of getting the requestorId from a function inside the javascript (this is not working), I’m just passing it as a parameter of my function call from the button.... and it works.
Thanks again for your support.
Kind Regards,
Djibril.
