Tata Consultancy Services
Last activity: 2 Dec 2024 8:35 EST
Pega robotics runtime v22 and v19 both are same machine
V22 Repository version working fine but while shift the older 19 version with package server it will not pick the package it return below issue
Logs:-
Failed to download new PegaRuntimeConfig.xml from server, will use cached file.
Downloading packages...
Executing request - https://robotmgr.qa.ampf.com/prweb/api/robotics/v2/packages/assignments
Get robot package assignment response code: 200
Get robot package assignment succeeded.
Setting event to show/hide remote splash screen. Mutex: PEGA_SHOW_SPLASH_MUTEX_71772
ClientPackageRepositoryService.GetUserPackage: Package download directory does not exist. Will attempt to create - 'C:\Users\bthara\AppData\Local\Pegasystems\19.1\Projects\PackageDownloads'
WebCacheService.DownloadFileFromRobotManager: Error while getting etag from server: 'WebException: Response Code 'InternalServerError'. Response Content Type 'application/json;charset=UTF-8'. Response Body 'Failed to get package binaries from repository. Unable to get the file from repository. There was an issue with the file path or repository configuration/connection.'. Friendly Message 'The remote server returned an error: (500) Internal Server Error.'.'. Server Url: 'api/robotics/v2/packages/binary/8D97872BE6FE4AC/1.153'
Logs:-
ClientPackageRepositoryService.GetUserPackage: Downloaded file should exist on disk but does not. File: C:\Users\bthara\AppData\Local\Pegasystems\19.1\Projects\PackageDownloads\Billing_Next_Day_Check - 1.153 - 8D97872BE6FE4AC.openspan
Downloaded 0 package(s)
