Constellation Cases Automatically Submitting After the Create Stage in Dev Studio Preview
I have a project with multiple case types, and any time I perform a "Save and run" on any of the cases in Dev Studio, the case automatically submits after the Create stage. I am met with a blank screen, and a pop-up message at the bottom of my screen that says "Successfully submitted!" In App Studio and in the actual application, the case proceeds normally without errors.
To fix this issue, so far I have tried:
- Checking the Flow Rule/Action of the next stage
- Checking the pyDefault case type rule for errors
- Simplifying the first step in the next stage
- Recreating the last process in the first stage, and the first process in the next (with different naming)
- Recreating the second stage
- Recreating an entire case type lifecycle
- Checking the Tracer for any errors
But I cannot seem to find why this is happening. I'm assuming this may possibly be a bug.
I have created a Tracer zip file from performing a Save and run on a case type but it is too big to attach directly. Here is a link to it if you would like to check it:
