ADM monitoring configuration about snapshot
We have encounter an issue on our predictor report generation. We found that the instances in Data-Decision-ADM-PredictorBinningSnapshot are very unstable. Sometimes we see the instances and sometimes we did not see them at all which result in the empty predictor report. Would that be the reason we set the monitoring configuration to only the latest predictor data? (see picture)
I have also check the DDS that daystokeepdata is set to 180 days so the snapshot should not be cleaned out so quickly. I have tried to run the pzRunADMMonitoringTasks manueally and I get the intances again, but in the morning when it comes to the time the agent run the monitoring task the snapshot got cleaned out again.
There are some days the instances were kept which is the time point I have made some reponses to the IH table. But it only last for few days. So if the responses are not the lastest one the predicotr snapshot won't be created? What is the definition of latest here? And how the setup affect the monitoring activity task? Thanks ahead for the answering or any suggestions.
