How to Reset fields in view during "on change" event of dropdown value in Pega Constellation
Is it possible to reset fields in UI everytime when a dropdown value changes in Pega Constellation
This issue was in version 8.8.3 but has been addressed in the Infinity23 and 24 versions. I'm unsure if it has been resolved in 8.8.5. Please create an INC ticket to confirm..
Configure the Form Refresh settings in the Flow Action rule to add a data transform whenever the dropdown Property changes. (attached screenshot for your reference).
Ramesh
@RameshSangiliThanks for your response.
I couldn't find "Form Refresh settings" in flowaction instead i configured "Refresh settings" in flowaction rule. But it doesn't seem to be working for my scenario. Are they both serve the same purpose?
In runtime, I traced by changing the dropdown value but the data transform didn't run.
Sure I will create an INC and check this with Pega team.
We have raised an INC with pega and it has been concluded that the above functionality is possible only when we upgrade constellation from 8.8.5 to latest.
Thanks.
@Thaslima Just FYI, when you have done the "Refresh Settings", just add the visibility to Always to whatever fields you are trying to reset.
