Constellation UI - Table Row Context Change
In a Constellation table, I'm trying to run the "Edit" option of a row within a different context than the original context. Has someone achieved the same?
Constellation design ensures a consistent user experience across all applications (Shifting from Customization to configuration in Constellation).
Can you please provide the use case? Also, could you check if Pega DX components will meet your requirements?
My use case is similar to below,
Suppose the table view is as below and the source for the view is List Data page which is created by default while creating the Employee data type (ORG-App-Data-Employee)
But suppose I need to differentiate the "Edit View" based on the country and I have a good number of different countries in the data type. Not only "Edit View", but also validations are different from country to country.
Support Doc
