FPT Japan
JP
Last activity: 3 Sep 2024 3:24 EDT
When using the default filter function on a Pega table, it is slow when selecting filter items.
Hi everyone,
I am facing an issue when using a table and the default filter feature in Pega. When I open the filter and click on the checkboxes, the time it takes to complete each selection is usually 3 seconds or more.
Specifically:
- I am using a table that displays 25 rows per page.
- The table has 3 columns that display data using a dynamic layout (marked in green in the attached image).
- The issue occurs when there are around 40 records or more.
- If I hide those 3 columns, the issue does not occur anymore. When I open the filter and click on the checkboxes, the response time is faster.
I have tried to investigate but haven’t found a solution or understood the root cause.
I hope to receive a solution that allows me to keep the current table setup but improves the response time when clicking on the filter checkboxes. Alternatively, I would appreciate knowing the cause of the issue.
Thanks.
