Charles Schwab
Last activity: 26 Jun 2024 10:36 EDT
Can we have add custom parameters in Runtime configuration file component, where the user can modify the value and user in the solution
Can we add custom fields in runtime config file and access the runtime config as an xml component in the automation and access fields and values from the runtime config file to use them in the solution.
Please suggest if this is possible or not. if not possible please suggest any other solution for the same requirement. Where we can access fields from outside the solution and modify whenever there is a change required without doing any code changes.
Thank you,
Anuroop
