Combinatie Bovemij Mn Services BV
Posted: Jun 14, 2024
Last activity: Jul 10, 2024
Last activity: 10 Jul 2024 1:27 EDT
Can you add and see an activity in the calendar of sales automation?
Is it possible to see the activities you create in Sales Automation in the calendar?
Now you can see the appointments in the shared calendars but you can't see the tasks in the shared calendar. But can you add the activities in the calendar.
***Edited by Moderator Marissa to add Capability tags***
Hey @PuckRas, thank you for asking. You can add activities to the Calendar Gadget, here's a description how to achieve this.
The steps describe the easiest approach with the least changes, but all Calendar Gadget configuration rules are available and declared as extensions, hence they can be modified as desired.
Note: all applied changes are available in the attached branch CalGadget <CalGadget_20240709T145854_GMT.zip>. Also, image upload doesn't work reliably, so screenshots are uploaded as attachments.
Step 1 - ensure that the relevant rules are available and correctly specified
The configuration requires specific data pages – in some cases they might already exist, otherwise you are required to create them:
For details related to this example of customer activities, please verify the rules in the mentioned branch.
Step 2 – update Declare Expression CalendarComponentMetaData
This is used later in the Calendar Gadget template configuration.
Step 3 – Configure the Calendar Gadget template
The configuration in the UI should like this now:
<CGConfig UI.png>
Activities are now presented in the Calendar Gadget
<CG Show CustAct.png>
Hope I could help - please let me know if you need further information.
Best regards
Mike
