Post Upgrade File listener issue
Hi all,
we have upgraded from 8.5.2 to 8.8.3 version for Pega platform + SIP, as well the server was upgraded, and it seems now the File listener is failing when testing connectivity
Status
Fail:Configuration
Message
Listener is not configured to run on current host [hostname] - update 'Listener Nodes' list.
Is there something extra that has to be run, so that it is picking up the correct information?
it is only failing when using NodeClassification Startup => using BackgroundProcessing. On the other options, it is fine
Thank you for help.
