Cognizant
Last activity: 8 May 2024 11:09 EDT
What are the key points to design a System Of Record Application in Pega
Lets say we are going to create a PEGA application, which will act like a database. Other applications would read or write(publish) data into that application. Data could be saved as draft and final mode. And also there should an archival logic.
What are the things one should consider while designing such PEGA application to get a most optimized solution.
(Case type, Datatype, Integrations and access control wise)
